Erratic fuel gauge , advise needed .
Hi Guys, hoping you can help , I have a e30 316 f89 with the M40 engine , the petrol gauge seems to be a bit erratic i.e. if I brake it goes up and if I accelerate it goes down ? im not to sure where to start has this is my first e30 so it is all new to me , I have found some paper work to say it had a new fuel pump at bmw a couple of years ago , would appreciate all advice , thanks
smithy318i
How much does the guage move ?
carlos_320i
- Contact:
Mine did that and I changed the clocks If I had of known this it would ov saved me £30
maplins sell the batteries,but check first to see what type the are as some of the later ones had the flat sort...and if you post an email address i have a how to pdf i can send you
but maybe you just need a new sender?
slinky2000
- Location: Ireland - North(Portadown) and South (Limerick)
- Contact:
DaveD, send me that link there too. stefan_ray [at] hotmail.com
sorry for interupting your thread but my fuel gauge reads full most of the time..give it a few slaps and it gives correct reading but still varies a small bit but hit a bump and it goes to full again????????
clocks or the sender in by the fuel pump or what is it?its common cause my friends is exact same
bmw engineering
always make you feel good by pretending you have full tank of petrol
I would appreciate that pdf, I have managed to remove the cluster I tightened a 7mil nut that holds the gauge in place im hoping this is what you mean ? took it for a drive and still doing the same , so I took it apart again found the batteries they are two round tubular ones they look ok but they don't look that easy to remove has the ends look like they are soldered to the contacts ? thanks for your help
ps E~ MAIL sent via pm thanks appreciate your held DaveD
Brian325i I'm not certain on this so I may stand corrected, I thought i heard once that some E30's have either 2 'tanks' or 2 sensors, and if one fails you are actually out of petrol when your gauge reads half full? I had a prob like this on an old 318iS as sono as I got to half full on gauge, she ran out... i might be completely wrong so if i am apologies as it was several years ago
slinky2000
- Contact:
I'll post up a link when I get home this evening and uplaod it to a server
I had the same problems on a car. It turned out to be a ground fault. So I had to track down where the ground attached under the dash. Plus back at the tank under the seat.
tannerman8807
Dave D you got PM::
For sale soon, 325 Touring (H) 1991 Jan. Auto 104K, silver BBS (black and silver) Mint sport interior. New front wings, very tidy, all bushes done front and back, Wheel bearings. Available this month. Email for further
