Ooops...
orpheus
Post Thu Apr 14, 2005 9:03 pm
Dash lights have gone - never had that happen before (and no, they're not just dimmed...).
If it's not the fuse, how the bejeezuz do you get to the bulb? (318iS) Cheers.
Guest
Post Thu Apr 14, 2005 9:06 pm
orpheus wrote: (and no, they're not just dimmed...).
Can you dim the dash on an E30? My dash is lit, but only just!
Where's the wossit to up the brightness?
orpheus
Post Thu Apr 14, 2005 9:09 pm
Turn the headlight knob
Martinaston
Post Thu Apr 14, 2005 10:25 pm
thats not very nice :lol:
johnono
Post Thu Apr 14, 2005 11:09 pm
:lol: :lol: :lol: :lol:
Post Fri Apr 15, 2005 12:04 am
Orpheus - pull the lamp and holder out of the rear ashtray, pull off the brown/white connector and connect it to the body of the car with the sidelights on.
If the dash lights then light at full brightness, then the problem is the dimmer unit in the headlamop switch
Fuse 23 is the relavent fuse by the way, but if it had failed the right side sidelights wouldn't work either.
There are several dash and instrument illumination lamps, some easy to get at and some nigh impossible. If you tell us where the dark patches are, we'll tell you how to get at the relevent ones.
