Leaking Shock Absorber
- Wookie
- Contact:
I noticed about 6 months ago that my rear left shock absorber was leaking, so I decided to replace it. Once it was in, all was well. I noticed again at the weekend while I was doing some work on the brakes, that this shock absorber is now leaking as well. What causes shock absorbers to leak?
There are two types of drivers: Those who dislike BMW drivers, and those who drive BMWs.
cliffybabe
- Powered by Nelly
is it the right shock for ur car??
whats ur car spec engine etc, have u lowered it, what wheels u running etc
kam-325i
- Contact:
If the travel of the shock absorber is not true/parrallel, it will cause the seals to fail.
- Wookie
- Contact:
Yes, it is the correct one. It's exactly the same as the one on the right side. Car is a 318i, standard suspension setup, with 195/50 15 inches. Other than that, all is standard...cliffybabe wrote:is it the right shock for ur car??
kam-325i
- Contact:
No, not the tracking. i mean the path the shock travels through, or more to the point, has the bottom shock mounting point had any damage, causing it to be out of line.irish-e30 wrote:by true running do you mean tracking??? could be right there!!
- Wookie
- Contact:
No damage since I've owned the car. Can it not be attributed to worn top shock mounts or other worn suspension bushings?
