proper name for cloth type insulation tape
beardymat
- Location: sheffield, city of steel, and rust apparently
hi chaps
going to be refitting the engine bay of my project and i want to replace the rotting insulating tape but i want to use the correct cloth type as pvc just looks cheap and will spoil the finish im after.
any idea what the official name for it is?
found some on frosts but the rolls are only 3 meter long and at £2.50 a roll seem a bit pricey to me.they just call it impregnated tape (ooer missus)
thanks in advance
thanks in advance
stuartgallafant
A man after my own principlesbeardymat wrote:hi chaps
thanks in advance
It is listed as a genuine part on realoem in 'equipment parts', or something like that. Surely the genuine kit would be the stuff to get?
http://www.realoem.com/bmw/showparts.do ... g=61&fg=15
Ta Da!
There you go!
I knew I'd seen it somewhere.
Ta Da!
There you go!
beardymat
cheers geezer, didnt even think of looking there for some reason.
might have your principles but not your budget im afraid
would have liked to tackle my car as you have yours.never mind,all in good time (just a pity my patience doesnt extend to resisting spending money lol)
- jokipea
Self-amalgamating tape isn't the same as the fabric tape. Self-amalgamating tape is a type of rubber tape that has to be stretched as it is wound around the wires so that it causes the 2 surfaces to stick together and become one piece. Once amalgamated it cannot be unwrapped like PVC tape, it has to be cut off.
mrLEE30
this is correct, and self amalgamating tape is available and used frequently in the jointing of HV power cables, but has no application in your car.Self-amalgamating tape isn't the same as the fabric tape
Better get my arse to the dealers then! My loom really lets the bay down.old_skool_2002 wrote:http://www.realoem.com/bmw/showparts.do ... g=61&fg=15
Ta Da!
There you go!
Well done 2002.
beardymat
found some on ebay
http://cgi.ebay.co.uk/RAYON-CLOTH-ELECT ... dZViewItem
im kinda impatient and cant wait till tuesday to order it.besides which i have a feeling that the part number may just superseed to the newer pvc stuff.could be proved wrong as bmw never cease to amaze me but 16 years in the motor trade have made me a little sceptical.
- Contact:
Its all under the 4 pot and M3 covers now, out of sight out of mind etc, I may do the visible bits but will deffo get some for the next loom I dobeardymat wrote:get it pulled back out a rewrapped,you know it makes sense
- Brianmoooore
You haven't seen the air inlet hose or the FPR pipe on my daily driver!!mrLEE30 wrote: self amalgamating tape is available and has no application in your car.
Half a reel always lives in the glovebox of my E30s. Useful stuff for repairing hoses in an emergency.
I've also used it to tidy up the ends of cables under the bonnet, where the little rubber sleeves have split.
I used some self amalgamating tape when i did my engine conversion on the wiring,
it looks neat and like factory i think. Didnt really think about emergency repairs on hoses, good idea!
'99 E39 M5
'93 E34 525ix Touring
As anyone who's ever had to dismantle the handiwork of an electrician from the 1950's knows, the old cloth “electricians tapeâ€a was self-amalgamating over a period of years as the adhesive was able to migrate through the cloth forming a solid mass which slowly set rock solid. The only way now through such a taped joint is with a Stanley knife. This never happens with normal PVC insulating tape.
For this reason it always seems to me that cloth tape sticks to itself better than PVC which is apt to peel back. It's good to know where you can still get it.
Cloth tape was only rarely called “self-amalgamatingâ€a however and that term only came into common use with the modern polymer tapes which chemically react to fuse together over a period of hours or so. Whilst they will repair hoses —a it's not an instant fix as they usually set relatively slowly.
- Brianmoooore
Loom wrapping tape normally isn't adhesive backed at all, so I don't think the ebay stuff is quite the right stuff.
