Central Locking
Markey
Sat Mar 31, 2007 6:39 pm
Hello,
Im going to look at another e30 tomorrow and the central locking does not work is there anything that i can look for to diagnose the problem to see how serious it is..
Thanks :D
Sat Mar 31, 2007 10:24 pm
It'll either be corrosion of the pins in the driver's door plug and socket (easy fix) or a flooded locking ECU. This results in a useless ECU, and unfortunately, quite often results in burnt out lock motors on the doors, the boot and the fuel cap. (not such an easy fix)
Unfortunately there's no easy way to tell which it is without dismantling the trim in the driver's footwell.
Markey
Sun Apr 01, 2007 12:16 pm
Thanks ill bear that in mind then on the price when i speak with him :)
