hi, my diff has been leaking quite badly recently and i was told that it would be better to change the hole diff insted if replacing the seals which is where it is leaking from, does anybody know if it would be better to use a diff from another car for example an 318i or 320i or somthing insted of an 316i diff ??
thanx
316i diff change !!??
- andrewpany2002
- andrewpany2002
ye i thought so, how about a 318is diff ? do you no the ratio for that ?
320Touring
correct ash!hoshy wrote:iS is 4.10, same as 316i and 318i (except tourings that are 4.27 afaik)
go to this website and click on the link at the left hand side for e30's
http://www.unixnerd.demon.co.uk/bmw.html
gives engine type, and final diffs found on the car.
also has a gearing calculator so you can play about
- andrewpany2002
so if i put a diff from a touring 316i or a 318i ill have betta acceleration ?
