cab rear window rubber sill swap how?
DJ_B4L
Mon Mar 26, 2007 10:14 am
i want to swap my cab rear window sill i have another window which has the sill on it already but i want to jus swap this over without swaping the window
has any one ever done this and how does it come off?
PIONEER AVIC X1, X1R, X1 BT LATEST SATNAV DISK WITH LATEST MAPS AND ALSO UPDATES FIRMWARE £20 POSTED PM FOR MORE DETAILS
Number plate for sale E30 2 HRD open to serious offers only will suit any E30
DJ_B4L
Sat Mar 31, 2007 3:48 am
any one?
mrLEE30
Sat Mar 31, 2007 11:00 am
would like to help but no idea what you mean? window sill?? what window sill? do you mean the plastic window or the rear side glass window or the window on your hardtop??
DJ_B4L
Sat Mar 31, 2007 4:52 pm
lol sorry i mean the rear electric windows they have a plastic sill on them so when they are fully closed they seal the front and rear windows together to stop wind and water coming through
them sills i want to know how i can swap them over as mine are worn and when i try to close the front window driver side sill catches
Splod
Sun Apr 01, 2007 9:53 pm
The seal on the front edge of the rear side window is bonded in place mate and I dont think you will get it off without destroying it. From your description it sounds as though your problem is more about adjustment of the front and rear side windows anyway.
There's a section on that in the online manual which you can find by going via 'Links' then to 'How to Guides' and then e30 manual. It's under 'Body Equipment' section 51-37-154. Alternaively the Bentleys manual is quite helpful if you've got one.
You need to start by checking your front side windows are adjusted right, then checking the angle of the rears when they are fully up and also the amount they are pressing outwards on the rear of the fronts. That will all possibly affect whether they catch on the fronts. See a previous thread http://www.e30zone.net/modules.php?name ... highlight= which covers the 'in and out' adjustment of the rears too.
Good Luck
Steve W
DJ_B4L
Mon Apr 02, 2007 10:33 am
thanks for the reply mate its not both windows just the driver one and its jus the sill because the rubber is worn on it
il try and check tho and see if its any of those u mentioned thanks
