crankshaft sensor
dobbey1
Post Sun Apr 10, 2005 11:22 pm
does anyone know if the crankshaft sensor on a 325 controls the spark and injector pulse or just the the spark as my 325 started to hold back when driving then it started to missfire and now it will not start and i have lost spark and the injectors are not pulsing anyhelp please :cry:
Andy335Touring
Post Sun Apr 10, 2005 11:50 pm
The sensor tells the ECU how fast the engine is turning over and the ECU then powers the coil and injectors apropriatly(sp?).
Not sure which of the following three things is most likly to have gone wrong but they all fit your symtoms.
ECU relay
ECU
CPS(crank sensor)
Or a bad electrical connection some where.
Good luck ;-)
dobbey1
Post Mon Apr 11, 2005 7:26 pm
cheers for your help i will give it a go :)
