cold start problems
kermitt
Post Fri Mar 09, 2007 7:43 pm
Help needed here urgently,
I have an E30 M3 full UK version (1 of 62 I beleieve) non cat and it is having problems starting from cold and is idling very rough. Runs sweet as a nut when warm though. Basically when I start it it will cut out unless I give it some beans to keep it going for a while and runs rough. It is not misfiring though and drives good still plenty of power too. Ihad already replaced the thermo, temp switch and temp gauge sender before this lot happened and have since changed the choke switch that sits next to the temp gauge sender in the water rail. I can see that it does not have the O2 sensor as it is non cat version. I have dismantled the airbox just now and the flap for the air flow meter is not binding or inhibited in anyway, please help I'm getting to my wits end and really don't fancy going to the stealers cos I have just bought a house and need the cash for that otherwise I will be the one having the beans!! :cry:
