M20 rough idle
cro320
Post Thu Mar 08, 2007 7:32 pm
well, my 320i M20B20 Motronic seems to have some idle problems. When engine is cold it works well but when hot it constantly goes between 600-900rpm, up and down all the time. This happens every day but sometimes idle is very good few moments and then start roughing. We replaced: air filter, fuel filter, fuel pump, sparkplugs, adjust valves at 0.25mm, cleaned ICV...everything seems fine but this bad idle making me crazy.
Any suggestions?
karldan
Post Thu Mar 08, 2007 7:36 pm
mine seems 2 b idleing rough 2 since i adjustid the valves. was running fine b4 :-x
cro320
Post Fri Mar 09, 2007 10:50 am
anybody?
rj
Post Fri Mar 09, 2007 11:42 am
You could check the coolant temp. sensor. I can't remember the exact specs but when cold it should read between 3-4k and fully hot 200-300 ohms.
Check the opeation and specs of the TPS, which you will find in the forum search engine.
Check for vaccuum leaks around the intake and did the ICV give the correct readings too?
Templ8e30
Post Fri Mar 09, 2007 2:07 pm
karldan wrote:mine seems 2 b idleing rough 2 since i adjustid the valves. was running fine b4 :-x
Sounds like you've adjusted them too tight, 0.25mm feeler guage should just drag slightly when pulled through the gap between the rocker adjuster and the valve stem.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
cro320
Post Fri Mar 09, 2007 2:41 pm
vacuum is fine, no leaks. We replaced some hoses but problem remains.
I will check temp sensor....anything else?
mash320i
Post Fri Mar 09, 2007 6:53 pm
might sound silly but u are ajusting the valves from cold???
