The Feeling She's Going To Step Out
J_Mac
Post Thu Mar 08, 2007 6:51 pm
Anything above 30mph and to a right hand bend thats the feeling i get, like she's going to step out, she even does a little bit. roundabout are the best example, i have bad camber and it's like when i do a corner the rear left wheel straighten up and go's on to it's full flat surface. It does it in the dry easy everytime. It feels like if i hammered it i would have some real arse end action but it doesn't i tryed, grips quite well altho it doesn't give the feeling it's going to :?
Doesn't do it the same left hand bends
I changed the rear left wheel bearing only (not the right aswell, altho i should) and after that i get this feeling, what have i done wrong.
stuartgallafant
Post Thu Mar 08, 2007 7:52 pm
did you...
put the circlip in? the hub nut on? do the wheel up tight?
J_Mac
Post Thu Mar 08, 2007 8:10 pm
yeah in the box (bearing) came two circlips and a split pin, gathered they were for other models, i put back what came out just one circlip, and yes everything went back on all ok, got it in the garden now, raised up, going to see if anything obvisous is wrong
J_Mac
Post Thu Mar 08, 2007 8:54 pm
The big 30-32mm hub nut worked it way loose? was nearly off! i know for certain i did it up,it was the last thing i did after the wheel nuts, anyways torqued up now, will have to wait till later to see if it was that. no doubt it was
