whats involved in ditching the cat setup?
a friend of mine has idle that drops and goes back up to normal quite alot...and lowish mpg
blue emp changed, no airleaks and throttle body setup perfect -
is it a case of unplug sensor and put in the bin? what about that cansiseter and fume retutn pipe into the throttle body?
will doing this give him any more shove as it seems a bit slow too.
how to ditch cat setup
E30Mark
I just removed my CAT, and fitted a standard non CAT front pipe & box. Disconnected the Lamda sensor under the battery tray, and left the carbon canister in place.
Would love to know if this is going to cause any problems!
What age is the car? some MOT places will demand a CAT on later cars.
As a follow up, why do Eurocarparts list the AFM different part numbers depending if you have a CAT or not?
PM for details
PM for details
liam012
oh er thats a good one-
i didnt realise therre were different AFM's (could that be causing the pinking on my 2.7?)
my friends car with the cat is an 89
emmission heaven
or hell depending on how green you are....
from the search i can only establish that without the sensor it will run open loop which is ok but i dont know exactl what that means.
emmission heaven
liam012
any more thoughts on this
i'm sure my mates sport is down on power and it fluctuates the idle a bit - i think the sensor is at fault but dont know how to disconnect it and if it will make it run worse some kind of limp mode or something?
