Post
Wed Mar 07, 2007 9:44 pm
ok i'm no mechanic and i've done two, on a mk2 golk and a vw polo which are suppose to be harder then bmw ones because the engines are mounted sideways and you've got drive shafts and all sorts in your face, bm's are spead out alot more, being rwd making it easier.
On the fwd's you drop the engine off the mounts on a jack and disconnect everything, cluch cable, gear selector, gearbox earth. Then with the gearbox lowered unbolt it and pop it off, cluch revealed, pretty simple to change over when you have the new one in front of you, put back together.
It not overly hard but time consuming and as i said not done a bm before but would have thought it's not to bad if you ok with a spanner. get your head under there and have a look
thought i'd reply cos nobody else did, if you atempt it good luck
