Sunroof drain inspection - Window removal help needed
GBE30
Post Mon Mar 05, 2007 9:41 pm
All,
After seeing Wildians thread abput the rotten sunroof on the poor old sport I have decided that I should investigate my 318is that has a leak! I may be able to save or prlong it life!
Has anyone ever removed,
a, rear side window
b, rear screen
How are they sealed?
What is the best removal method?
Is this an easy job? Any advice would be appreciated as I want to get this checked out.
Gareth
wildeian
Post Mon Mar 05, 2007 9:50 pm
Hi Gareth,
The rear window (like the front) has a retaining ring in the middle of the seal. It's a 2 part ring, 1 piece along the bottom of the window, the other all the way around the top. It has 2 clips either end of the bottom piece. Once the retainer is out the screen pushes out easily.
The side windows (if pop out) have 2 8mm nuts behind the centre post trim, and 2 screws on the window handle.
It might be possible to tilt the sunroof and look into the roof void with a torch. Save you some work too!!
HTH
Ian
GBE30
Post Mon Mar 05, 2007 9:58 pm
Cheers Ian,
I dont have the pop out windows....yet!
I will do the tilting thing tomorrow and take a look!
Fingers crossed eh!
So anyone else popped out the rear side windows?
Gareth
316eyes
Post Tue Mar 06, 2007 1:13 am
Fixed rear side windows are held by 2 x 8 or 10mm nuts concealed behind blanking plugs on the inside of the door pillar. Once these are removed it is just a question of carefully "popping" the glass out of the rubber.
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
