86 325 won't rev past 1500rpm
littlejim
Mon Mar 05, 2007 6:41 pm
driving home it just lost power (but still idling ok) and when I held the throttle all the way down it would take a couple of seconds then it would rev up to 1500 then drop down to idle, then a couple of seconds later it would rev again and drop back.
so I drove it home holding it at 1200 rpm and when about a mile from my house it started to rev past 1500.
I haven't taken it out on the road since but left it idling a few times and it hasn't done it since (it has a slight miss fire when reved hard but this might not be part of the same problem)
Mon Mar 05, 2007 7:04 pm
How is your throttle cable? and how is the throttle body itself?
Nelly
Gumbo
Gumbo
Mon Mar 05, 2007 7:06 pm
Rotor arm + Dizzy cap check
"I F**KING LOVE YOU GUMBO"
littlejim
Mon Mar 05, 2007 7:09 pm
the cable looks ok and the throttle is opening fully.
fugazi33
Mon Mar 05, 2007 7:15 pm
Fuel problem? Fuel pump on the way out/pressure regulator pipe split or something?
Andyboy
Alpina Colada
Mon Mar 05, 2007 9:26 pm
Could be the speed sensor on the bellhousing. When this fails the engine will idle fine but just won't rev.
Shinobi1
Have you checked the afm slide is not stuck ? might be worth a look .
cheers paul.
littlejim
Tue Mar 06, 2007 5:26 pm
Its been running ok for the last two days.
I haven't done anything to it.
