Morat wrote:Personally I'd try a good whack on the wing near the indicator before pulling anything apart.
BrianMooore will be along to shoot me later, I'm sure.
TBH, I often do this.
Usual problem with front indicators is that they are not waterproof, and, although the holder doesn't corrode, cheap bulbs do!
In this case though, it's probably as Spadge says - the connector isn't in properly.
When refitting a front bumper, you have to balance the bumper in one hand and attempt to push the plugs in properly with the other.
Only other cause of front indicator problems that I've come across, is that the wire to the indicators often gets damaged where it goes through the front panel in a front end shunt.
Definitely nothing to do with the column stalk, indicator flasher unit, fuses or hazard switch. There are no plugs and sockets exclusive to the front indicators, except for the ones on the back of the light themselves.
One other remote possibility - never discount the efforts of alarm fitters! Not inconceivable that one has cut the feed to one indicator in an attempt to splice a connection to it!
