quick bush question
dark_sounds
Post Mon Mar 05, 2007 9:59 am
on a standard 325, the bush required is concentric right? or does it make much difference with an eccentric bush (lower wishbone bush)
assume car is lowered, with potential for wider wheels.. if itmakes a difference??
cheers :)
liam012
Post Mon Mar 05, 2007 10:03 am
i installed the eccentric recently and noticed the car is a lot more eager to turn in if thats possible, most of all i seem to get a lot more feedback up through the steering wheel - it weired me out at first but now i love it and would never get concentrics again as i have got so used to it.
dark_sounds
Post Mon Mar 05, 2007 10:10 am
and what ride setup do you have?
wheels, suspension, etc? does it make a difference??
Directed CompX's 12"... 2off. 1000 watts RMS, dual 2ohm VC. 90£ each!!
8600 Luna Phone 480 POSTED BNIB
liam012
Post Mon Mar 05, 2007 10:24 am
35mm drop front and rear
205 55 15
to be honest i cant say if the height of your drop will have a + or - effect if you fit these bushes
for me they worked very well
dark_sounds
Post Mon Mar 05, 2007 10:29 am
cool cheers for that,
anyone else with any views? reviews? :)
Demlotcrew
Post Mon Mar 05, 2007 10:38 am
Yeah ride height is irrelevant with bushes.
Liam you are spot on with your observations. I would also add the high speed stability and the uniform braking when going round bends and on the straights.
Andrew
dark_sounds
Post Mon Mar 05, 2007 12:40 pm
eccentric it is then :) cheers guys
