LSD check + rust blisters.
MarkP
Post Sun Mar 04, 2007 6:22 pm
Hi,
I just bought a sport and want to know how i can check the condition of the LSD?
I have searched and people have mentioned its fooked if it whines but is there any other way as the exhaust makes enough noise? Seems to go round all right though 8)
Done a check round the car and all seems good apart from a few small rust blisters here and there, they are about the 1/4 of the size of a 5 pence piece. Can I treat them or do they need drastic treatment like cut out,welded,filled and sprayed?
tomson
Post Sun Mar 04, 2007 7:53 pm
with regards the diff, if its fooked you will definately hear it over the exhaust!!
Post Sun Mar 04, 2007 7:57 pm
Take the rear seat out to hear it better :wink:
MarkP
Post Mon Mar 05, 2007 9:41 pm
But still not sure on the noise so if the LSD if fooked what will happen? Will it seize up or what?
Anyone got any knowledge on these tiny blisters?
tomson
Post Mon Mar 05, 2007 9:59 pm
the diff will wine worse than yer mrs or it'll seize up completely if its that bad!
handpaper
Post Mon Mar 05, 2007 11:30 pm
Just to clarify, LSDs 'fail' when the clutch pack wears out, turning them into (effectively) an open diff. The pack is 'lifed' at 10 hours of lock-up time, so if the car has been drifted or has been regularly driven hard, this may have happened.
A diff that is really wearing out gets *noisy*. You'll hear it over the exhaust (if it's not blowing or a silly-loud 'performance' system). It's most noticeable when there is little or no load on the engine/transmission, and the speed is moderate to high (50-70). It sounds a bit like an electric drill winding down. In this state it's unlikely to explode/lock up, but it *will* get worse the more it is used. If it sounds like an angle grinder winding down, change it - fast!
