ported polished head
dark_sounds
Post Sun Mar 04, 2007 5:46 pm
whats actually involved in doing such a thing??
maxfield
Post Sun Mar 04, 2007 5:50 pm
boring it out so that the port is bigger. on a proper gas flow table. i wouldn't advise this at home with a dremel.
not sure about the polishing the maybe a dremel type thing with polishing bit on the end
stuartgallafant
Post Sun Mar 04, 2007 6:30 pm
about £500 worth of work!! if you can find someone that will want to do it
liam012
Post Sun Mar 04, 2007 6:39 pm
maxfield wrote:boring it out so that the port is bigger. on a proper gas flow table. i wouldn't advise this at home with a dremel.
i did mine at home
with a dremel
i didn't try and do too much though as i knew i didnt know what i was doing
got the chambers like mirrors
matched the intake ports as the 320i head ports were much smaller than 325 manifold
i did not polish the inlet side
i got the outlet like glass too
no dynos no before and after results as it was a new engine rebuild
if i had more balls i would have lliked to take more metal way from where the valves are but didnt want to weaken the tract so didnt bother
edit: it really did take a long time a lot of slow and careful work.
if yo go diy practice a bit on an old head first and make your mistakes there...
dark_sounds
Post Sun Mar 04, 2007 6:43 pm
whats a gas flowed head?
Directed CompX's 12"... 2off. 1000 watts RMS, dual 2ohm VC. 90£ each!!
8600 Luna Phone 480 POSTED BNIB
liam012
Post Sun Mar 04, 2007 6:52 pm
maybe i have it wrong but i presumed gas flow is a term to decribe a head optimised for the flow of gas into and out of the chambers.
at first i thought it was a method or even a machine that ran on gas... but i am pretty sure it means the earlier...
i would love to be corrdcted if i am wrong as i have often wondered too....
dark_sounds
Post Sun Mar 04, 2007 7:00 pm
yeah maxfield threw me off, as what i had assumed ported and polishing is, is what you said liam, expanding the ports and then polishing... then maxfield said something about gas flowing table and it threw me off lol
out of interest, if the cylinder head was compleatly stripped, surely a machine shop can port it out precisely, and then you can take it to a polisher dude to polish? or polish yourself?
liam012
Post Sun Mar 04, 2007 7:02 pm
i mocked up a set of gaskets to use as a stencil - id say whilst not scientificly precise i was "on the money" which is good enough for both me and my wallet which aslo anwers your last question - i didnt have that money to pay other people to do it.
maxfield
Post Sun Mar 04, 2007 7:07 pm
Sorry yes gas flowing is to do with getting the right shape size and all that.
liam thing is you probably didn't get all the same volume in each cylinder it might affect power.
i would like to see before and after dyno results with a home made head.
I'm guessing you didn't polish the inlet as rougher surface better the fuel/air combine?
dark_sounds
Post Sun Mar 04, 2007 7:10 pm
i just dont see the point in paying someone if you can do it yourself, eg, bodywork i dont have the tools, facilities or know how, hence happily pay someone to do it, most engine work i can do(given a bit of time and familiazation) my dad ported and polished using a dremel on his old triumph spitfire Mk2 lol along with a full engine rebuild and new pistons and bore out etc etc etc..
Post Sun Mar 04, 2007 7:16 pm
David Vizard's book on tuning the A-series engine provides alot of pointers and tips on how to go about it. Maxfield is right about leaving the inlets a bit rough though - this helps with the atomisation of the fuel/air mix. If you polish them all smooth, it can actually reduce the power output, and screw your economy!
Kos
Post Sun Mar 04, 2007 7:22 pm
dark_sounds wrote:i just dont see the point in paying someone if you can do it yourself, eg, bodywork i dont have the tools, facilities or know how, hence happily pay someone to do it, most engine work i can do(given a bit of time and familiazation) my dad ported and polished using a dremel on his old triumph spitfire Mk2 lol along with a full engine rebuild and new pistons and bore out etc etc etc..
gas flowing you cant do properly at home,
its smothing the inlet and exhaust ports to get quicker flow of gasses in and out the engine
porting is easier to do at home, you just open the ports up, but if you dont open the manifold ports to match it is pointless
the are some myths and ideas on this subject, if it works or not, and i say it does, and i've seen the gains
if you want a significant improovment i'd leave it to the pro's who can put in even bigger valves to get the most of it
griffin motorsport are known for building some fast m20's as have bbr, both of them had serioud head work with cams
mid range torque and top end power is gained if done correctly
stuartgallafant
Post Sun Mar 04, 2007 8:21 pm
strictly, porting and polishing is something of fine art in a dying trade. nobody wants to do the work, so the ones who do charge a fortune. nobody wants to pay a fortune, so the ones in the trade dont want to do the work anymore. its a viscious circle...
porting a head, as said, removes metal from the port, allowing you to increase the size of the port, in turn, allowing more air into the engine > more air = more power...
its the polishing thats the difficult bit. your outlet ports should be like an absolute mirror, smoother than any pornstars pussy you've ever seen. however, the inlet side should be smooth-ish. the tools they use to polish ports create a pattern similar to the pattern you find on a cylinder bore. this pattern traps air in certain points and passages and creates a vortex, which inturn allows for a more thorough air/fuel mixture.
the gas flowing side of things is even further complex. as maxfield stated, its a 'bench'. the head is placed on/in the machine with flow pipes to and from the head, with metering devices being used to calculated air flow, vortex, speed and density and probably more things too!! when someone says their head has been 'gas-flowed' it means the company that has ported and polished the head, have used a flow bench to measure the air flow and 'design' it the best they can for that head
as kos said, if you dont match the inlet manifold ports, all the way along, its a wasted effort, as is not using a big throttle body. the best gains seen from porting and polishing, etc, is using ITB's and wild cams, designed for maximum air flow/intake at wide-open throttle
stuartgallafant
Post Sun Mar 04, 2007 8:37 pm
forgot to add, one of my instructors at Technical, BMW GB, has his own business as a side line racing mini's. he prots all the heads on his own a-series engines all the time, but he said even he wouldnt go near an M42 or an M20
