325i wont start!
wullie325i
CAUTION - unreliable trader!
Post Sun Mar 04, 2007 12:08 am
hi
my 325i wont start.its a 1990 g plate.
when i turn the key i just get a click and all the power seems to drain out of the car as all the lights dim away to nothing.there seems to be something happening with the white relay in the little black box with the 3 relays in it as it seems to make a little click.
any help welcome as i need to get it running asap!
thanks
wullie
Post Sun Mar 04, 2007 12:14 am
You have a dead battery or connection to same!
wullie325i
Post Sun Mar 04, 2007 12:16 am
hi
the battery is fully charged so its not that.
wullie
Sanchez
Post Sun Mar 04, 2007 12:29 am
have you check the battery for power.
I had the same problem. Gona get a new battery from National Tyres £55 BMW varta one.
wullie325i
Post Sun Mar 04, 2007 11:51 am
hi
i have tried 2 different batterys and i charged both of them fully and also tried getting a mate to jump start me and still all i get is a click.
wullie
dimebag_from_hell
Post Sun Mar 04, 2007 11:57 am
Same thing happened to me!! left the alarm on it going for a month and never looked near it! Went to start it, just heard a click. Tried charging the battery, no use.....it was totally fu cked and had to buy a new one.
Daadji
Post Sun Mar 04, 2007 12:50 pm
Can be alternator or even dizzy cap and arm
jamesh1977
BEWARE Zone Thief
Post Sun Mar 04, 2007 1:38 pm
was the jump leads proparly conected when you tried to jump it ? you cheacked the starter ?
TINSNIPS
Post Sun Mar 04, 2007 1:44 pm
YOU MAY HAVE A BAD EARTH OR YOUR STATER MOTOR MAY BE TOTALY SHORTED OUT
Post Sun Mar 04, 2007 1:45 pm
Daadji wrote:Can be alternator or even dizzy cap and arm
None of these will stop the car cranking, which is what the problem is!
If you just get a "click" (presumably from the starter motor area), then it could be a duff starter motor, but, if the lights on the car dim right out at the same time, then it's a problem with the battery or it's connections!!
You say it's a 325, but not what model. Assuming it's a saloon your battery is in the boot, so battery connections includes the fusible link in the small lead from the battery, and the connections at the phantom battery terminal on the engine bulkhead.
wullie325i
Post Sun Mar 04, 2007 2:22 pm
hi
yip the battery is in the boot i will check all the connections again and i dont think there are any problems with the starter motor.
wullie
