any ideas? as you can imagine its doing me nut in a bit!
locked out of my car!F***K
oakey
went down to M&S earlier, when i got back to my car in the car park it would not open
i have no keyholes on the doors and it should open with the remote locking. the car still recognises ive pressed the button (hazards flash, immobiliser LED turns off) but the doors stay locked.
SPADGE
Don't you have a boot lock or doesn't the c/l work on yours from the boot?
There is a simple way of getting in but i won't disclose that on here PM me your number.
oze30
Try pulling the door handle whislt beeping it. What about the boot?
oakey
is there anyway of opening the bonnet from the outside?
SPADGE
Yes but it may mean breaking a grill paneloakey wrote:is there anyway of opening the bonnet from the outside?
oakey
the key dont turn in the boot lock.
spadge- i have pmd you my number
SPADGE
Not recieved mate bell me 07718 901737
you shouldn't need to break anything, PM sent Oakey
lets not discuss how to break into an E30 on the forum! keep it via PM and no hint posts either!
SPADGE
Who is discussing it Simon? I asked for his number and gave him mine
oakey
dont mind breaking a grill panel really. just thinking i may have knocked a wire loose earlier when i was cleaning it?
i think i need to consider getting a key hole put in my door after this!
oze30
Or beating out the ski hole and then leaving the key for the boot.
There's many ways to get into a car if you know how,
eh spadge
eh spadge
oakey
i finally got in there. thanks spadge
top bloke.
new problems-
i cant lock my car cos if i do ill need to "break into" it every time,
my petrol flap is locked shut,
my boot is locked shut,
what do you lot recon- a new alarm system?, get an autoelectrician over to rob my money? phone Cobra and get one of there blokes to come and check it out?
(its a cobra alarm/ C/locking system btw)
new problems-
SHAZ325iSPORT
id have the elctric looked at first mate,had the same problem on one of my old sports,check the following-
central locking module located drivers side speaker kick panel
on both doors,there is a plug which you can see when you open the door,it connect the doors electrics to the rest of the cars electrics,take the rubber cowling off and pull the plug,it will seperate,just check the connections(pins).
oakey
thanks shaz i'll check that lot out
may i ask what was causing the problem for you?
SHAZ325iSPORT
it had a lserline central locking alarm on it,when you push the button on the key fob it wouldnt lock the doors or unlock,it would only flash the indicators giving the signal thats its either locking or unlocking.
so i checked the central locking module,that was fine,so checked the connection between the door and electrics,when i pulled the plug out the drivers side had loads of green corrosion,so i pulled the drivers side loom out complete and changed it.
pushed the button on the fob and there you have it,it started working.
same problem you have aint it?
oakey
sounds like the same problem to me.
I can hear the locks doing something when I press "lock" on the fob (as if thats working ok) but when i go to unlock it no sound at all!
did yours do this?
When you pulled the drivers door knob up, did the other door, petrol flap and boot open?
did yours do this?
SHAZ325iSPORT
if you pull the passenger side door lock up the rest will unlock(petrol cap/door locks/boot lock)
yes mine would make a noise too,like the locks are trying to operate but are not.
id say before spending any money check them bits,if you are in east london bring it down i will take a look at it for you.
oakey
if i get stuck ill take you up on that offer mate.
i'll try the passenger door and see if that works
thanks for the help
thanks for the help
SHAZ325iSPORT
RED/BLACK WIRES
oakey
the red and black wires in the loom by the door hinge as shaz was saying?Brianmoooore wrote:RED/BLACK WIRES
Yes! Chop them off. Join them together. Use the search function.oakey wrote:the red and black wires in the loom by the door hinge as shaz was saying?Brianmoooore wrote:RED/BLACK WIRES
eko
- Old timer
Agreed,Red/Black wire first!
If it hasnt already been done it will need doing at some point.....gaurenteed
Failing that give Shaz`s suggestion ago,common failure there too!
oakey
sorry people- im struggling to find anything regarding this using the search function.
do i need to connect the red&black wires on the drivers side, the passenger side, or both?
many thanks
dave
many thanks
dave
Bob_S
I would say it was the old red/black wire thing, I did it on the 318is I had on drivers side and also the central locking ecu somehow gets wet and screws up?
Bollocks to this 24v scrap!
oakey
ive just looked at the wires behind the rubber on the drivers side and it looks nasty! theres alot of green corrosion and one of the pins has broken off inside the plug! i would assume this is causing me my problems.
what would be the best way to fix it? replace the loom with another from another car?
Remove the driver's footwell speaker and find two seperate red/black wires going to the driver's door pillar socket. Cut both of these wires and join the two ends not going to the socket together.
oakey
thanks brianmoooore. i'll give that a go and keep y'all posted
SPADGE
Good luck with it mate
Put the rubber boot back on the plug before you push it back in.
oakey
just had a look behing the kick panel (F me there is alot of wires) i can see a red wire but there is no black wire going to the drivers door pillar socket! there is however a Vlong chunky black wire amongst the wires that appears to be looped back on itself??
what do ya reckon?
i took some pics just in case they were any use to anyone but its taking me ages to load em up!
what do ya reckon?
oakey
these are the wires that go to the door pillar socket:
this is the only black wire there is (the one tied up with tape)
SPADGE
Push the socket for the plug out of the pillar and get it inside so you can see the back of it.
The will definatly be some evidence of the red/black wires on the back of the socket.
Looking at that wiring several 'destroy it yourself' merchants have been in there
SPADGE
Also
On your last pic there is a screw at the bottom
That and one the same further in hold the c/l relay in place.
Take them out and lift the relay out and make sure its not been swimming
oakey
i think there may have been a communication error here on my behalf.
am i looking for two wires the same that are rea and black? not two wires- one red and one black?
and just to make sure- i connect the two wire so that they do not go into the socket yes?
