Radiator is spitting coolant :-(
318i1989
Post Sat Mar 03, 2007 5:08 pm
hi there, I wondered if i could ask some advice. A few days ago i noticed my temperature gauge went sky high on my 318i m40 so i checked the coolant and there was none there even though it was changed last week.
I topped up the coolant yesterday and checked it today and it had all gone!So I then topped it all up again this afternoon and let the car idle for 5 mins,
I then saw the coolant flowing out the bottom of the header tank :-O
Any ideas what's wrong with it? btw. It last had a new radiator a couple of years ago so it's not that old....
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Sat Mar 03, 2007 5:11 pm
first thing to check is the clips on the pipe - the pipe itself and I think there's a drain screw down there also. Hopefully it's one of those items!
If you do need a new rad I've got one you can have - it's in the midlands, Shrewsbury. Otherwise if that's too far then somebody else will have one for sale I'm sure.
Post Sat Mar 03, 2007 9:33 pm
318i1989 wrote:Any ideas what's wrong with it? .
In short - but right whatever someone bu**ered up last week, and hope no permanent damage has been done.
Difficult to believe the two things aren't connected!
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Sat Mar 03, 2007 11:13 pm
Just being nosy - but wtf?
Post Sun Mar 04, 2007 1:32 am
318i1989 wrote: even though it was changed last week.
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Sun Mar 04, 2007 10:43 am
lol- cheers brian - clearly I'm blind :D
318i1989
Post Sun Mar 04, 2007 1:20 pm
oops, really should have rephrased that. I meant to say that I regularly check the fluid levels and the coolant was just topped up last week (not changed) ! sorry for the confusion.
Any more ideas?
thanks
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Sun Mar 04, 2007 1:33 pm
did you check the things i mentioned in my first post??
318i1989
Post Sun Mar 04, 2007 4:59 pm
yea i checked those things buddy but still no luck. Is a pain in the arse considering how new the existing radiator is.
could it be anything to do with my head gasket? I was already concerned about the head gasket lately due to the amount of "mayonnaise" that's been appearing all the time despite the frequent servicing I give the car
cheers
Post Sun Mar 04, 2007 9:02 pm
318i1989 wrote: I then saw the coolant flowing out the bottom of the header tank
Do you mean where the semi see through bit joins the black plastic?
The header tank has a gasket around the bottom of it and this may be leaking.
Could be because the gasket wasn't renewed when the new rad was fitted. (New rad came without header tank?), the screws have come loose, or it could be excess pressure because of a pressure cap that should have been changed under a recall several years ago and wasn't/
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Sun Mar 04, 2007 9:11 pm
dunno, mate - I just wanted to point out the more obvious things. If Brian is on the case he should see you good as he's a bit of a legend around these parts.
J_Mac
Post Sun Mar 04, 2007 9:16 pm
mayonnaise under the oil cap is not a good sign mate, look for white smoke out the the exhaust but this would not be the problem your talking about, more the opposite, when you said it overheated, that may of damaged the head gasket then or even worse cracked the head.
Back to your leak, you said you could see coolant comming out of the bottom of the header tank, surly the fault lies there (by that i mean you can see it) damaged or split pipe or the header tank split itself?
I hope the head issue isn't as bad as it sounds for you mate
318i1989
Post Sun Mar 04, 2007 10:14 pm
cheers for your help guys, the leak isn't coming directly out of the bottom of the header tank, it looks like it's coming out more towards the bottom right of it (where it sits next to the rad).
Tomorrow I'll try and take a pic of where it's gushing out from cos it's quite difficult to explain/picture in my head :-)
cheers
