Inlet manifold gaskets
Nissar
Post Sat Mar 03, 2007 1:55 pm
All,
I need some tips or advice on changing the inlet manifold gaskets... i changed one a while back coz it as leaking and now it turns out another one is leaking.
when the engine is running i can hear some air being sucked in and then when u turn of the engine u hear air gettin in from somwhere and it stops.
Any advice anyone has on changing the gaskets would be appreciated.
E30Mark
Post Sat Mar 03, 2007 3:26 pm
Might help if you say what engine it is...
Which gasket did you change last time? which one is leaking now? spray some propane / brake cleaner around the area and find where the leak is.
PM for details
