rear brake pipe T-piece
sam325is
Post Fri Mar 02, 2007 2:45 pm
to get to this utter b4stard of a T-piece do you have to drop the subframe ? i have to replace all the pipes that go into it for the mot :x :x :x :x :x
Chris-W
Post Fri Mar 02, 2007 5:11 pm
You don't have to, but it is an absolute git unless you do. If you're desperate to not take the beam off, you could always cut the lines and relocate a new t-piece somewhere accessible (not sure where though), making sure the new lines are secure.
dazleeds
old skool raver
old skool raver
Post Fri Mar 02, 2007 5:16 pm
Chris-W wrote:You don't have to, but it is an absolute git unless you do. If you're desperate to not take the beam off, you could always cut the lines and relocate a new t-piece somewhere accessible (not sure where though), making sure the new lines are secure.
i did this on my old se
made up a little bracket to hold the new T and had it welded to the chassis
by the wheel well you also have to make sure all the pipes that join to it still have the soring olates in use or itll fail
not that hard to do if you really dnt wanna drop the axle
www.oldskoolfantasy.co.uk
Post Fri Mar 02, 2007 5:52 pm
I did this job the other week, no subframe removal, petrol tank stayed where it should and the exhaust was left in place.
You can get at it pretty easy, not as bad a job as I was expecting, I replaced the two short rear pipes (from the tee to the flexi's with genuine pipes from the dealers as they come with ends flared), the steel spring clips and fitted some Goodridge braided hoses.
sam325is
Post Fri Mar 02, 2007 8:40 pm
daz what are soring olates mate :?
Chris-W
Post Fri Mar 02, 2007 9:13 pm
plates
dazleeds
old skool raver
old skool raver
Post Fri Mar 02, 2007 9:20 pm
sam325is wrote:daz what are soring olates mate :?
oooops typo :o:
spring plates
sam325is
Post Fri Mar 02, 2007 9:30 pm
ahh right... i dont think i will be going about doing it that way now anymore. im going to get a better spanner tommorow and do it properly...i was using a Hellfrauds one earlier and it is a lean mean rounding off machine
Chris-W
Post Fri Mar 02, 2007 9:34 pm
The Halfords Professional brake nut spanners are excellent - just as good as Snap On / MAC etc. I had to buy some the other weekend through necessity and am well impressed.
Post Fri Mar 02, 2007 9:55 pm
Chris-W wrote:The Halfords Professional brake nut spanners are excellent - just as good as Snap On
How dare thee :eek:
I used a hexagon 1/4 drive socket (Snap On) if it helps 8)
sam325is
Post Fri Mar 02, 2007 10:22 pm
hmmm well this one is now bent and the end on it isnt strong enough so it widens and slipps of the nuts. everyone has their own experiences of tools, and im finding this spanner completley s**te. i need to get a spanner with teeth on the inside so it bits on to the nut ...cant remember what they are called now
sam325is
Post Sat Mar 03, 2007 8:04 pm
daz when you were saying about spring clips did you mean on the 2 pipes that join to rubber hoses near the petrol tank?
they have a nasty bend in them and its being troublesome to refit the new ones.
could i just join the hose and pipe together near the hole(by petrol tank) without the little u shaped fixing bracket. i would just secure the hose joined to the pipe by zip tieing them to the hole insted of the pipes joinging through them if you know what i mean
