E34/E32 hellas are exactly the same as E30 hellas smoked or otherwise (facelift ellipsoid ones), so you could remove the lens from any E34 and fit the lens to your smoked Hella unit, only difference is the main beam and driving light lenses are different. the projector unit is also a common item
bosch lenses are a different diameter to Hella (hella are 1-2mm bigger), and as said the locator tabs for the glass are in different places, but with some creative filing the main beam lens can be made to fit i dont know about the driving light, but if you can find the correct one why bother.
below are my lights after i smoked em and broke one bosch main beam lens, i could only find a hella in the scrappies.... it was hard to fit and the outer ring took some heavy persuasion to fit but i defy anoyone who can tell the difference unless they get real close to my front end (and in which case i would run em down anyway
