This is an interseting one,
I have noticed the last two days that when i clutch or come to a halt when driving instead of dropiing a t straight down to idle it drops to 1200 fro about 3 seconds then down to idle. It does this consistantly.
no air leaks, tps set up correct, afm fine,
i still have also the warm start problem and the ice cold start is pure perfection - starts perfectly, as soon as up to temp, harder to start
infact it will not start without throttle
now writing this i have had a brainwave that maybe my tps is not finding closed thottle position contact easily/properly
must do multi metre tests on 3 pins tomoorw
maybe when i start the car it is using a fuel map based on open throttle therefore requiring air(throttle) to start and when i am driving and take my foot of the accelerator it takes a few seconds to get to idle as it doesnt realise foot is 100% of the acceleraor.....
sorry bit of a ramble
adjust throttle cable = worse pinking? why?
liam012
k
Yep, does sound like the tps could be your problem, let us all know what you find
liam012
ok gave the system a good once over cleaned everything contacts checked tps, throttle body stop icv all good.
did notice there was considerable slack on the accelortor cable so set it nice and close with 1mm play,
wow car is ALOT more responsive dare i say faster of the line - i mean like considerable smoke the wheels faster.
but the pinking is now ALOT worse i really have to mind the throttle now as any load and i can really here it rattling.
that makes no sense to me at all
can anyone help? i just dont seeem to be able to get it together with this car, its one thing after another....
Ant
- Retired Team Member
Liam, check the WOT switch is being made, usually full load over 5K or so the car will run on the WOT map with preset load/rpm in the lookup table, no WOT being made will result in part throttle mixtures and timing @ WOT, not a good idea on a high comp stroker.
No more trips to WOT until the pinking is sorted, what are the plugs like ? look like they've been seasoned with salnt'n'pepper ?
Stuff the moronic in the bin, break out the MS dude
Email FTW
liam012
that is the strange thing i get this pinking not over 5k? infact the car runs brilliant if you cane it
but i dont
where i have the problem is WOT from 1200 in fourth and fifth and even third - it seems to iron out by about 3300rpm
i know i have to intstall the MS
its just getting the time...
but i dont
