How can i improve it? The more it locks the better
handbreak not great, how to fix?
s1oww
The handbreak on my 325 tourer holds the car in place just, but doesnt work that well.
dazleeds
- old skool raver
take rear wheels off
get a torch and a flat screwdriver and if you look thru the hole in the rear disc/drum
youll see an adjuster move the wheel on the adjuster with the screwdriver and youll soon
have a nice tight handbrake keep checking tensoin as you do this
before you start loosen the 2 nuts on the cable at the handbrake lever under the rubber or leather surround
hth
Daz
hth
Daz
www.oldskoolfantasy.co.uk
jcjdavis1
Hi It might be a good idea to take off the drum and check the shoes as they might be goosed.I have just had a look at mine and had to get new shoes.
If the brakes have previously been adjusted by some muppet tightening the handbrake cables, then the shoes may have been rendered scrap by the way they will have worn. (The recipient for my M50 engined E30 came with a recent large invoice for servicing which included "adjust handbrake". Cable nuts had four washers added under each of them, and were tightened about as far as they would go!!!!)
If you don't know the history of handbrake adjustment on this car, make sure you slacken these right off, only tightening them when the brakes are properly adjusted.dazleeds wrote:before you start loosen the 2 nuts on the cable at the handbrake lever under the rubber or leather surroundDaz
Once set, these should never need adjusting again.
