Not the plug housing, the actual female / male pins that are used inside these?
I'm talking about Item 5 in the pic below
Appreciate the time all.
Exactly.orangecurry wrote:You want the part no of the females that go inside number 5?
These specific one's - do they have a size and official name?mrLEE30 wrote:the pins are normally soldered onto the end of the wires and pushed into the plastic connector housing, these male and female pins can be found at almost any motor factors here where i live so i cannot imagine they will not be available in uk...failing that try asking a shop that fits ICE or good old RS componants.
mrlee
I pulled apart a number 5 the other day - they are females; why do you want to know the part no.? If you want some, go to the scrapyard and stuff a load of them in your pockets?Royalratch wrote:Exactly.orangecurry wrote:You want the part no of the females that go inside number 5?
Or the males if they're male.
