Recently got my front shocks replaces to pass an MOT, but now got a new problem. I've done about 20 miles since the replacement, and in the last couple of miles I've noticed a grating sound coming from the front right wheel. It sounds like something's running metal on metal, so my first thought was the brakes, but they weren't hot to touch. Might have been some slight grooves in the brake disc, but I'll have to have a look in daylight tomorrow. When the car moves slowly (inches per hour, with me listening to it) there's more of a rattling sound, and it seems to alter when the power steering is being used - seems to sound like crunching. Any ideas anyone? Anything that could have been put back badly after the shocks were renewed that would explain it? Please help, it's made me very sad and wonder how much longer I can justify the amount this car's costing me - another year and there won't be any of the original components left at this rate...
Doesn't seem worse when using that brakes either, and doing emergency stops made no difference to the sound afterwards.
Grating, screeching and crunching front wheel - please help
chief
sounds like ball joint or rod end problem ???
grab em with a heavy grip and riggle it a bit
what happens
what happens
Don't you wish there were a knob on the TV to turn up the intelligence? There's one marked 'Brightness', but it doesn't work.
Shield behind the brake disc bent and touching the disc?
Dr Firefly
- E30 Zone Doctor
That sounds plausible actually Brian - will have a look tomorrow. If you're right that will confirm your status as a living deity in my eyes! The number of times one of you're posts has saved me....
But I'll have a look at the ball joints etc once I've got the car up on a jack tomorrow too.
Hoping it's nothing serious...
mrLEE30
loose wheel nuts?
Hyperion
i am gonna watch this closely. I have the same problem Firefly, you get a grinding noise when pulling up to a stop while pressing the brakes lightly, i was going to jack my car up on the weekend and take off the front wheels to see if anything was touching.
e30bmlover
- Ac Schnitzer prophet
lol iv had those!!! the wheel nearly came off!!!! some ''mechanic'' was supposed to have done them up!mrLEE30 wrote:loose wheel nuts?
Dr Firefly
- E30 Zone Doctor
First thing I did was check the wheelnuts! Like I said, there wasn't any difference after using the brakes, so I didn't think it was to do with the brakes particularly, was more worried about something like a front wheel bearing or something. As it turns out, I found a little stone that had got wedged between the brake shield and the disc, which made a god-awful noise when I twisted the disc. Took it out, and car back to normal! Very very very pleased - the best bit is I'd psyched myself up to a £150 repair bill, as I don't have the time at the moment to do a front wheel bearing myself - now I can spend it on some new seats, and a map light!
Ps Hyperion, stupid question I know, but you're sure you haven't worn down your brake pads? My dad's E46 made the same kind of noise when it was running on bare metal...
Jesus325iTouring
- Frog freak !
I had this at the weekend,amazing how a stone smaller than a pea can make such an awful noise,I only had a couple of miles down country lanes to drive home you should have seen the looks I was getting from the Sunday afternoon walkers!Firefly2005 wrote:First thing I did was check the wheelnuts! Like I said, there wasn't any difference after using the brakes, so I didn't think it was to do with the brakes particularly, was more worried about something like a front wheel bearing or something. As it turns out, I found a little stone that had got wedged between the brake shield and the disc, which made a god-awful noise when I twisted the disc. Took it out, and car back to normal! .
