Hissing from Engine, hunting/lumpy idle, flat spot at 4k rpm
hitman
Post Mon Feb 26, 2007 12:32 pm
I just wanted to share with you guys the problems I was experiencing on my 325 touring as above. All resolved with a new set of inlet manifold gaskets.
Previously I thought it was a vacuum related problem. But a poke about with a rubber tube to focus the sound around the engine bay pinpointed the air leak a the inlet manifold on cylinder 6.
Upon opening the gasket on cylinder 6 was found to be completely wrong!
Car is running super smooth and has also stopped kangaroo-ing too!
Hope this helps someone else at some point.
Hitman[/list]
cliffybabe
Powered by Nelly
Powered by Nelly
Post Mon Feb 26, 2007 12:54 pm
yeah mine done the same thing, i didnt even notice th e hissing Nelly and Marc did at lakeside cheers guys :thumb:
Mines running so much better aswell and feels alot stronger 8)
hitman
Post Mon Feb 26, 2007 12:59 pm
It's amazing how 6 quid and a little help from friends can do!
Gives me motivation to fix the other things on the car that need attention.
smudger1767
Post Mon Feb 26, 2007 1:41 pm
Hi guys sorry to jump in but where does the hissing come from as Im having the same probs.
hitman
Post Mon Feb 26, 2007 1:50 pm
The hissing was coming from inlet manifold entry point for the 6th cylinder (closest to the dashboard). Basically, for me it was gasket numbered 7 that was faulty but at the far end of this diagram: http://www.realoem.com/bmw/showparts.do ... g=11&fg=40
Like I said earlier, a little rubber tube was most useful in pinpointing the source of the hissing. Just put one end near your ear and the other end can be used to probe around in the engine bay.
Good luck!
kam325itouring
Post Mon Feb 26, 2007 2:30 pm
yeah mines doing the same but the other end, on number one!! but im gonna do the throttle body at the same time when i get the dosh!! winkeye
