Advice on throttle body
smudger1767
Hi there I have the M20 engine 20ltr and I have just noticed on the throttle body where it connects to the inlet manifold there are two pipes that come off either side, are these supposed to move, as both of mine are loose. These have what looks like splines on both of them.Any suggestions appreciated.
handpaper
The left hand one connects to the rocker box breather (1" pipe), the right to the brake servo (3/4" pipe(s)). If they're loose they are probably leaking and may give you a weak mixture.
smudger1767
Right so they shouldn't move in and out, they should both be a tight fit.
Ant
- Retired Team Member
options for this as follows....
1, remove TB assy and the elbow section, peen the ends of the elbows over so they are a tight fit again, refit and enjoy.
or
2, pop the elbows out, clean the area and use some araldite to fix them firmly in place, be careful of excess resin getting into the TB area and dont run until the resin is fully cured.
those are the two methods I'd employ, 1st one is more "correct" but harder to get right, 2nd will work well provided you can wait for the curing time
HTH
or
HTH
Email FTW
smudger1767
would Locktite do just as well ( blue stuff that secures bolts ).
surj
silicone the elbows to seal them off
smudger1767
Sorry surj I dont understand what you mean.
