DRIFTBOY
Post
Sun Feb 25, 2007 7:59 pm
I am aiming to replace the rear brake back plates as mine are rusty and knackered!
The drive flange in the pic that the disc is bolted to is giving me the trouble.
To remove this - must I remove the driveshaft ?
Thanks,
Martin.
wildeian
Post
Sun Feb 25, 2007 8:03 pm
I'm having the same problem too, if anyone can help
ian332isport
Post
Sun Feb 25, 2007 8:21 pm
It's a driveshaft out job, and then the hub can be pushed/pulled out. Unfortunately, this will wreck the bearings, so you'll need new ones of these as well. Getting the bearings out/in is no easy task either, and really needs the correct (expensive) tools.
Ian.
DRIFTBOY
Post
Sun Feb 25, 2007 8:26 pm
ian332isport wrote:It's a driveshaft out job, and then the hub can be pushed/pulled out. Unfortunately, this will wreck the bearings, so you'll need new ones of these as well. Getting the bearings out/in is no easy task either, and really needs the correct (expensive) tools.
Ian.
I guess I'll live with the crappy handbrake for now then!
Thanks Ian!
Martin.
ian332isport
Post
Sun Feb 25, 2007 8:28 pm
DRIFTBOY wrote:I guess I'll live with the crappy handbrake for now then!
What's happened ? Pins pulled through ?
DRIFTBOY
Post
Sun Feb 25, 2007 8:32 pm
ian332isport wrote:DRIFTBOY wrote:I guess I'll live with the crappy handbrake for now then!
Yep!
Around the holes for the pins it's all rusty and the holes are now too big.
I've bodged it for now with some modified washers!
Martin.
wildeian
Post
Sun Feb 25, 2007 9:05 pm
Me too!
I've taken the complete rear 'axle' off my sport for a transplant... seems easier!!
Andy335Touring
Post
Sun Feb 25, 2007 9:20 pm
Tis a bitch but doable, search for my user name in this section for my heath robinson bearing change
DRIFTBOY
Post
Mon Feb 26, 2007 12:51 am
Andy335Touring wrote:Tis a bitch but doable, search for my user name in this section for my heath robinson bearing change
Thanks Andy, found it no problem!
I haven't got a sledgehammer!
Yet!
I think I'll wait for a weekend when I haven't got much else on!
Andy335Touring
Post
Mon Feb 26, 2007 7:29 pm
yeah, leave your self plenty of time just incase.
At some point i've got to replace the front brake shit guard because mine has rusted badly and was rubbing on the disc. It was making a racket so i ripped it off today.
Which of course means i've got to have the hub off/change the bearing, oh joy !
ed325i
Post
Mon Feb 26, 2007 7:56 pm
Mine is the same I havent got any hand brake shoes in at the moment just have to leave it in park.
BadDave
Post
Mon Feb 26, 2007 8:25 pm
All you got to do to the front is remove the hub/bearing assembly Andy(36mm socket).
Even if the rear inner shell stays on the stub axle you can prise it off before you remove/replace the backplate and you can re-use the existing hub bearing assembly. Remember to grease it up before you refit it as well.
ed325i
Post
Mon Feb 26, 2007 8:28 pm
I have taken the front ones off for better air flow around the disc.
Andy335Touring
Post
Mon Feb 26, 2007 8:29 pm
Cheers for the info, glad to hear it sounds easier than the rear
BadDave
Post
Mon Feb 26, 2007 8:30 pm
I've got the same problem on my touring.
Gonna order parts tommoroww/wednesday.
Gonna get a cheap local mechanic to do it(he had to use a large slide hammer when he did the wheel bearing)which aint got
BadDave
Post
Tue Feb 27, 2007 6:22 pm
Been to the stealers and the plates are £11 Each.fitting kit £20
and if you get h/brake shoes then thats another £41
All plus vat
DRIFTBOY
Post
Tue Feb 27, 2007 7:00 pm
I got new handbrake shoes at E.C.P. for £17.51 incuding vat!
I think they do free delivery for orders over £50 too, might be worth getting a shopping list together if you don't live locally to one of their branches.
Martin.
BadDave
Post
Tue Feb 27, 2007 7:38 pm
DRIFTBOY wrote:I got new handbrake shoes at E.C.P. for £17.51 incuding vat!
Martin.
I know
E.C.P of EUROPARTS or your local motor facrors/car shop
Much cheaper
Just thought people should know what the stealers charge
buster
Post
Tue Feb 27, 2007 7:41 pm
Andy335Touring wrote:.
I thought id buy a pair of these for the 5 stud m3 struts i've bought.Dealer wanted £60 ish each ! !!
Needless to say,i'll do without
DRIFTBOY
Post
Tue Feb 27, 2007 7:42 pm
Fair enough, I just didn't want you to spend money where it's not needed!
I was surprised how cheap the backplates were though, dealers aren't always as bad as you think they are going to be!
DRIFTBOY
Post
Tue Feb 27, 2007 7:44 pm
BadDave wrote:I know
Much cheaper
DRIFTBOY
Post
Tue Feb 27, 2007 7:46 pm
Oh, I c****d that up!
I can't delete my first reply!
BadDave
Post
Tue Feb 27, 2007 8:48 pm
Appreciate the comment
However
Being a stereotypical tight arsed SCOTSMAN(short in the arm and thick in the head)
,I try and avoid going to the dealers or garages purely to avoud paying there hugely inflated prices
Granted,the "replacement parts"may not be up to exactly the same standard os OEM fit parts,however,they are usually up to the job in hand
