URGENT HELP NEEDED
snoops
Major Helmet
Post Sun Feb 25, 2007 6:56 pm
may not be urgent but am i supposed to be able to put my electric windows down or up when the car is off and the key is out?
i was going to paint my needles red in the instrument cluster, unbolted everything apart from disconnecting the cluster but i had an urgent call and so had to put everything back together pronto, after i done this i noticed i could put my window down but couldnt turn the stereo on while the car was off?
may be nothing but is this right? if not how can i rectify?
E30Mark
Post Sun Feb 25, 2007 6:59 pm
Windows should work when the doors are opened - with or without the ignition on.
PM for details
snoops
Major Helmet
Post Sun Feb 25, 2007 7:08 pm
Never knew that but the odd thing was that ever since i bought the car the rear drivers side window didnt work from the fron or back but earlier when i got out the car it worked perfectly then i locked the car, just now went to check and it doesnt work.
loose connection or something?
Post Sun Feb 25, 2007 8:09 pm
Dud switch in the front console is the most likely. Second most likely is the switch on the rear door card.
Swap the switches around as a check.
They are easy to strip down, clean and renovate.
