Right,
In the middle of removing an M20 engine with auto box out of my old mans touring.
The two torx bolts at the top of the bellhousing that attach to the engine are proving to be a f**ker to get off.
What tool do you chaps recommend using? Been down Halfords but nothing seems to be suitable enough!
Alternatively we are thinking of just taking the engine and box out in one as the box will be coming off eventually anyway.
What do you guys recommend?
Martin
Bellhousing Torx Bolts.
Phatz
bigdek
pull the engine and box together.
saves alot of pissing about m8
Jon_Bmw
- Dangerous when thinking
You can use a 8mm 6 sided socket on them, with various kinds of extenders and a UJ. Or use the proper female socket if you are particularly anal.
I would have thought removing the engine and box together is probably the easist way as bigdek has said.
Phatz
Yeah I guess we'll have to remove the engine and box together then.
Thanks for your advice fella's
Cheers!
Cheers!
I would always remove engine and box together, but with an auto, it has to be tilted right up at the front.
To get at these two bolts in the car, you need to remove the gearbox crossmember to drop the rear of the box down, and then use very long extension bars to get a torx socket on them from the back of the box.
Jon_Bmw
I somehow struggled and got them off in situ.
IIRC this is what i used, all half inch bits
SOCKET--4inch extension bar--UJ---12inch extension bar---rachet.
although it might have been: SOCKET--UJ---4inch extension bar---12inch extension bar---rachet
Bit of a knuckle smasher, but not overly bad.
Turbo-Brown
- Boost Junkie
If you can pull the engine and 'box forward by a couple of inches, you can get a socket (I'd use the torx one if it were me!) and breaker bar in there and not have to struggle with extensions and the like
