Im trying to chnage my inlet gasket (thanks Marc for noticing the air leak
This pipe has a spring at the bottom of it how do i disconnect this pipe??
Neil
tried pulling it, its not movingstuartgallafant wrote:just pull it you tart!!!
and when you come to putting it back on, make sure its located properly at both ends...
i know it would be nice, instead its gona diebazza93 wrote:if it was a chrome pipe this would'nt happen![]()
na ben wont let me spray itbazza93 wrote:you did'nt get it chromed then neil
WHY???!!!cliffybabe wrote:Someone had cut the bottom edge of the pipe down and had packed it out with some washers,
god knows some clever muppet im guessing, It looks like they bent the bottom end of the pipe and trimme dit downBrianmoooore wrote:WHY???!!!cliffybabe wrote:Someone had cut the bottom edge of the pipe down and had packed it out with some washers,
stuartgallafant wrote:cliffybitch!!
