No brakes!
jmc330i
Post Sat Feb 24, 2007 12:34 pm
Had a bit of a focusing moment on the way home last night - approached a roundabout at 40-45mph and no brakes. 8O Well, I say no brakes, it did lock the rears at the last minute 8O
As it is at the moment, the brakes do work but the pedal travels right to the floor before anything happens and I can feel it pulling the rear brakes rather than the fronts.
It hasnt leaked any brake fluid (the reservoir is still full) and pumping the pedal doesnt make any difference. I did notice the revs waver a little when I pumped the pedal.
Any ideas where to look first - MC/servo???
James
'91 325i Sport
'93 318i touring 16v
jmc330i
Post Sun Feb 25, 2007 2:29 pm
Bump 8)
James
'91 325i Sport
Post Sun Feb 25, 2007 2:33 pm
master cylinder it sounds like to me, sounds like there is no bias anymore
kam-325i
Post Sun Feb 25, 2007 2:34 pm
If the revs are waving around, i would suspect the vacum system/master cylinder.
Post Sun Feb 25, 2007 2:36 pm
Very odd - normally only happens when you get a leak in the front circuit and the resevoir empties, or a one off can occur if something jams in a pad, and pushes a piston back into the caliper.
Must be something with the m/cylinder I should think.
jmc330i
Post Sun Feb 25, 2007 2:46 pm
Cheers guys 8)
Typically, the one spare thing I dont have is a master cylinder :roll:
Will rob the M/C off my Sport and see if that does the trick - would it be worth while swapping the servo as well? I have the spare from my Sport and I know that works.
James
'91 325i Sport
Post Sun Feb 25, 2007 2:59 pm
Won't be the servo as such.
jmc330i
Post Sun Feb 25, 2007 3:26 pm
:thumb:
Will swap the M/Cs over and go from there.
James
'91 325i Sport
jmc330i
Post Mon Feb 26, 2007 1:09 pm
Swapped the master cylinder this morning and that solved it. Not sure if its bleed 100%, but the brakes definitely work :woohoo:
Cheers guys :thumb:
James
'91 325i Sport
