2.8 conversion using an m52 crankshaft??
Post Fri Feb 23, 2007 10:48 pm
In this months total bmw mag there is an feature on 2.7/2.8 conversions for the m20 engine, has anyone on the zone done the 2.8 conversion using the crankshaft from a 2.8 m52 engine and con rods from a 2.0 m20 engine?
The feature was good and explained what basic components were needed
(crank, rods, pistons) and what alterations are needed but what i need to know is what crankshaft main bearings and what con rod big end bearings to use (m20/m52)?
I would very much like to do this conversion as it seems to be a lot simpler than the 2.7 plus its an extra 100cc!!!!
Also, any ideas on where to get a good second hand 2.8 m52 crank?
Any information on the 2.8 conversion would be helpfull,
Thanks.
Post Fri Feb 23, 2007 10:52 pm
It's all been covered on here very recently in great detail! Use the forum search function.
maxfield
Post Fri Feb 23, 2007 10:59 pm
The man you want to be speaking to is Andyboy
Post Fri Feb 23, 2007 11:23 pm
Brianmoooore wrote:It's all been covered on here very recently in great detail! Use the forum search function.
Have tried but cant find anything. :(
csl
Post Sat Feb 24, 2007 12:32 am
bss325i, leave that bloody nice low miler alone ! :D
ed325i
Post Sat Feb 24, 2007 8:44 am
Post Sat Feb 24, 2007 10:52 am
If its a crank your after I will be stripping an M52 in the next few weeks :wink:
Post Sat Feb 24, 2007 2:10 pm
csl wrote:bss325i, leave that bloody nice low miler alone ! :D
Sorry fella but its got to be done, 2.5's are to slow for me but i will build a seperate engine and keep the low miler one spare.
Post Sat Feb 24, 2007 2:14 pm
DanThe wrote:If its a crank your after I will be stripping an M52 in the next few weeks :wink:
Hi, is it a 2.8 engine and any ideas what year it is, apparently the webbing on the crank is bigger on later engines and may fowl early m20 2.5 high comp pistons which i intend to use.
What sort of £ are you looking for?
maxfield
Post Sat Feb 24, 2007 2:59 pm
IIRC the M52 is the 2.8 and M50 is 2.5
Post Sat Feb 24, 2007 7:04 pm
If anyone on the zone has done this conversion i would like to hear from them with regards to the bearings! :mad:
Post Sat Feb 24, 2007 7:54 pm
Its a 98 engine, never heard of the webbing thing, wouldnt you want to lighten the pistons anyway? winkeye
I will decide on a price once ive stripped and inspected it 8)
I would of thought the M52 bearings are the ones to use
Post Sat Feb 24, 2007 8:05 pm
DanThe wrote:Its a 98 engine, never heard of the webbing thing, wouldnt you want to lighten the pistons anyway? winkeye
Ok then, when you strip the engine could you let me know if the tdc sensor ring holes are on the rearmost hub as per later engines. According to the article there are changes in 98 to the 2.8 m52 (with the introduction of the e46 i guess) so what im after is a 95-98 crank (fom an e36/e38/39)
