Hi,
What's a good test to see if a diff is an LSD when it's not on the car.
Hold input shaft and turn one output shaft and feel resistance and the other one doesn't spin in reverse?
Of course I'll look for the S tag first.
LSD
hoshy
- E30 Zone Wiki Guru
Chris-W
hoshy
cool - thanks.
just to confirm - mirror is open? and do I need to fix the input shaft?
Chris-W
hoshy
awesome - cheers.
Templ8e30
Even a good tight open diff will turn the output shafts in the same direction if one of them is turned by hand.
Best way is to grasp both output shafts and try to turn them in opposite directions, if you can it's an open diff, if they're locked tightly together then it's an LSD.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
hoshy
cool - I'll check both ways - thanks
