smashed sump, problem with oil going around engine.
MOODY
Post Fri Feb 23, 2007 5:00 pm
:cry: :cry: i have purchased a 325i but it had a bump and smashed sump, so i got the sump, oil pump, and the oil cooler, i have had them fitted to see if the engine is ok, the engine started but the oil light did not go off so we took the oil cooler pipe of to see if the oil was circulating which it was not, so we starded it again then we checked the oil filter to see if there was oil there but no there was not, so i have not tryed it again as it will damaged the engine, i do know that the engine is not seized, has anyone got any ideas what it can be, the only thing i changed in the sump was a oil cooler, can that be faulty the previous one was not there only the brackets to which it bolts on is there any other thing i should be checking for
:cry: :cry: :cry:
suzie650
Post Fri Feb 23, 2007 10:34 pm
Can you fit a pressure guage in the oil pressure sensor hole to see what's really happening? And tested the pressure sensor before that?
Post Fri Feb 23, 2007 10:37 pm
M20 oil pumps sit right down in the sump, with only a short pick up pipe.
How badly was the sump damaged? Any chance that the pump has been damaged?
suzie650
Post Fri Feb 23, 2007 11:14 pm
didn't he mean he got a new one?
Post Sat Feb 24, 2007 12:03 am
suzie650 wrote:didn't he mean he got a new one?
So he did!
I would suspect a problem with the shaft that drives the oil pump.
MOODY
Post Sat Feb 24, 2007 1:06 am
So he did!
yes i have replaced it with a second hand pump as i was checking if the engine still runs, when you say the shafts were do they go and can i change them, the sump was in bits, and the oil pump was broken too, i have only fitted a new sump and replaced the oil cooler is there a special way to fit the pump, :cry:
Post Sat Feb 24, 2007 10:14 am
Oil pump is driven by the cam belt, by the shaft which originally was used to drive the distributor in its old position above the alternator.
Look up the bits on the ETK or realOEM, and you'll see a long shaft with hexagonal ends that drops the drive down to the pump.
MOODY
Post Sat Feb 24, 2007 3:28 pm
Brianmoooore wrote:Oil pump is driven by the cam belt, by the shaft which originally was used to drive the distributor in its old position above the alternator.
i have opened the top and there is a cog and no hexagonal end there at all, can i get one and drop it in without taking the sump off ,and is that why its not pumping oil around, 8O
MOODY
Post Sun Feb 25, 2007 12:58 pm
:cry: :cry: can anyone tell me how i have to fit the shaft and the hexagnol end that drives the oil pump, would i have to strip dowmn the sump again and were does it go into exactly, i tryed takeing the hexaganol end from a car from the top but it would not come free, do i have to take it off from the bottom, please shed some light on this, :cry: :cry: :cry:
Post Sun Feb 25, 2007 1:43 pm
Sorry, I can't help you on this one I'm afraid. Because of the inherent reliability of M20 bottom ends, I've done very little work on them, but I'd be surprised if it can be done without taking the sump off, or at least withdrawing the jack shaft driven from the cambelt.
MOODY
Post Sun Feb 25, 2007 1:51 pm
:D thanks for the help anyway brian. :cry:
