316 engine idling problems..
koonibba
Post Fri Feb 23, 2007 2:25 pm
Hiya
Am new to the E30 experience! Ive just got my hands on a 1990 E30 316 (young driver) and when I start the engine the engine is tring to find revs while idling, and sometime just stops.
Also, when the engine is cold, and I am approaching traffic lights, when i come out of gear, the engine dies. This mostly happens whe the engine is cold.
Any ideas???
Thanks!
Post Fri Feb 23, 2007 10:58 pm
Check that the throttle position switch is working properly. Also, consider changing the engine ECU coolant temperature sensor (hidden under the inlet manifold, about half way along.)
--alpina--
Post Sat Feb 24, 2007 12:00 am
Otherwise, whack a 325 engine in and go faster. winkeye
jimi
smithy318i
Post Sat Feb 24, 2007 1:10 am
Brian. What is the correct procedure after changing the blue temp sensor? run engine for 10 minutes then switch off ? Do you need to disconnect the ECU ? WHat reading should the blue temp sensor be in ohms ? Also, would unpluging and reseting the ECU while the engine was warm cause problems?
Post Sat Feb 24, 2007 10:04 am
No procedure at all for changing the blue temp sensor - just unplug, unscrew, screw new one in and reconnect.
Temp sender reads approx. 3000 - 4000 ohms when cold and about 300 ohms when hot.
Unplugging and plugging in the ECU when the engine is warm makes no difference. The only thing that gets reset is the idle settings.
Barx325i
Post Sat Feb 24, 2007 2:57 pm
Could be the hose from the Air Flow Meter to the pleneim chamber leaking.. grab it when the engine's running & see if it improves things..
koonibba
Post Sun Feb 25, 2007 9:32 am
thanks! will try it all out and see what works!
