bigger injectors : m20
tommype30cab
hi everyone, ive just bought a 2.7 engine for the cab. its the low comp version and it was rebuilt 22k ago, anyway the guy who sold me it threw in a set of 3.5l injectors and i thought id better check that they would fit and the car would run ok, they look identical to the 2.5l injectors other than they have a beige top. how much performance gain will i get with them and will it be miles per gallon or gallons per mile? he he. thanks for the input
"Racing is life. Anything that happens before or after is just waiting" Steve Mcqueen
oakey
you wont get any perfofmance gain i wouldnt have thought mate. it'll just run richer maybe... although im not sure.
maxfield
It will overfuel without the right mapping.
- Homo Hair
what do you mean by low compression version?
injectors will do fuck all other than create bore wash imo
tommype30cab
its got a superchips ecu aswell, dont know if this would make a difference to the injectors. i did wonder what a difference it would make cos i havent heard it mentioned in this forum before, although my mate had a 318 with 2.0l injectors and that helped a bit. it also backfired and popped a flame at the redline wich was amusing
jhonno the low comp version means that when it was bored out the block wasnt decked as much, meaning its more suitable for a turbo conversion so ive been told, thanks for the help everyone
march109
stock 2.5 inectors should run fine, 3.5l will over fuel I would have thought.
Ant
- Retired Team Member
Dont fit the M30 units !!!!!!!
the "superchip" will have upped the fuel flow over stock in any case, you'll be overfuelling a good 25% on the yellows.
If you're concerned, get a 2.7 specific chip from the shop link dude, tested, proven and safe
Email FTW
tommype30cab
thats settled that then, thanks everyone
--alpina--
I have a set of M3 e36 injectors in my fuel rail, i got the ecu re-mapped and tuned the Co2 and runs sweeeet, reason i fitted these injectors were simply cos they were from a new engine as i pulled them out, so no need really to get the old injectors all cleaned up with new seals e.t.c. but does run real good, midrange and onwards, otherwise stick to 325 injectors cos i used them and had no worries/problems e.t.c.
jimi
jimi
reggid
if your running a low comp m20b25 with O2 it will only really overfuel during cold start as the O2 sensor will trim the fuel at part throttle.
Even at WOT in open loop mode it mananges to utilise the O2 data from closed loop mode in the form of an overall correction factor which can affect the WOT map aswell and this is from experince.
So if the base part throttle map is incorrect it can stuff with the WOT map this applies to cat equipped cars.
non cat cars will be rich all the time
tommype30cab
--alpina--
i have a set 325 injectors that i sent to BOSCH dealers to clean up and fit new ring seals and end caps e.t.c. basically they cleaned up the spray pattern which when i fitted them i felt more power to the car, but to clean up injectors costed me £100 and they supplied a printed diagnostic sheet of before and sfter spray pattern percentage.. now the injectors are just sitting in a tin box unused due to the E36 M3 injector fitment... so they possibly up for sale...
J.
J.
tommype30cab
pm sent
Andyboy
- Alpina Colada
325i injectors are good enough for a 210 bhp C2 2.7 'Pina. That's all you need to know! More fuel does not mean more power unless you can get more air in (throttle body/cam etc).
