oily water
burroski
HI to all. can you help me i have a 325i touring and iam losing water, having to top up once a week, now a have noticed some oily sludge around the cap,cant seem to see any water coming for anywere,what have i done
Hath
sounds like a headgasket mate.. ( usually my comical reply to any problem)
however it acutally does sound like the headgasket..
Sounds like a cracked head to me, I'm afraid, but you could be lucky.
The crack, if you have one, will be at the bottom of one of the rear most two cam bearings.
If you get the cooling system up to pressure and run the engine with the cam cover off, you can often see beads of water coming out from the bearing, although yours may not be losing water fast enough at the moment.
Keep an eye on the level and colour of the oil. Mayonnaise for oil and an increasing oil level are not good news!
burroski
the oily water is coming the radiator cap is that headgasket or worse cheers
burroski
is it ok to drive for about a week till i get it fix
Could be either, but I've said which I'd bet on.burroski wrote:the oily water is coming the radiator cap is that headgasket or worse cheers
Probably - just keep an eye on the coolant level and the colour of the oil.burroski wrote:is it ok to drive for about a week till i get it fix
