rear brake pipes
sam325is
Post Thu Feb 22, 2007 8:11 pm
my e30 failed mot on brake pipes today. not too bad except for the pipe that runs from the front of the car to the rear.
anyone know any tricks on how to fit a new one without removing petrol tank etc
old_skool
Post Thu Feb 22, 2007 8:54 pm
You don't need to remove the petrol tank mate. Just need a little patience.
Chris-W
Post Thu Feb 22, 2007 8:56 pm
As above - problem isn't the fuel tank, it's getting access above the rear beam that is tricky.
sam325is
Post Thu Feb 22, 2007 8:57 pm
so do i need to remove anything to fit that long brake pipe from front to rear?
Chris-W
Post Thu Feb 22, 2007 9:00 pm
Front-Rear line joins the rear lines at a t-piece bolted to the floorpan above the rear beam. Soak it well with penetrating oil before you try to get the line off. There is *very* little access up there.
In a perfect world the rear beam would be off!
sam325is
Post Thu Feb 22, 2007 9:01 pm
what if its not a perfect world? winkeye
Chris-W
Post Thu Feb 22, 2007 9:05 pm
Skin yer knuckles, cut the line and try to get a socket on the brake nut, then try not to rip the t-piece out of the floor pan!
sam325is
Post Thu Feb 22, 2007 9:07 pm
hmmm :cry: what do you mean by cut the line? judging by what you are saying it doesnt sound as if its possible?
Chris-W
Post Thu Feb 22, 2007 9:09 pm
I mean that as you are replacing the brake line it is a better idea to cut the line at the nut so that you can get a socket (preferably 6 point) on the nut rather than risk rounding it off with a spanner. It's hard to access anyway, so with a spanner you are likely to do so.
sam325is
Post Thu Feb 22, 2007 9:11 pm
ahh i get ya. my main concern is weather it is actually possible to get the pipe over the beam without removing it
Chris-W
Post Thu Feb 22, 2007 9:13 pm
No problem - it's just removal & tightening of the nuts which present an issue.
sam325is
Post Thu Feb 22, 2007 9:16 pm
right well what i will do on those is soak them in wd 40 chop the pipe as you say heat up the nut and get a socket on it.
i thought it was a big issue because when i looked 2 days ago i remeber thinking how the **** am i going to get the pipe to fit through such a small gap, but i will give it a go and get back to you with my findings.
Post Thu Feb 22, 2007 9:26 pm
Mmmm! It's not 'neccessary' to remove the fuel tank, but it's a lot easier if the tank (or rear beam) is out for any other reason!
