engine cut-out
k130
Post Thu Apr 07, 2005 9:53 am
Hi
My engine cuts out on roundabouts and tight turns. I dont think its a fuel problem as it always starts first turn afterwards, maybe a loose connection somewhere? Anyone have any idea where to look first?
320Touring
Post Thu Apr 07, 2005 10:26 am
is it only right hand bends?
does it occur even when the fuel tank is full?
if it only happens when its low, may be something to do with the pump.....
what engine is it? m20's (6cyl) should always have a fuel pressure of between 2.5 and 3 bar...
Maybe check the fuel pressure regulator, to see if its dropping pressure?!
However, if it only occurs when the car is cornering to the right, its more likely to be the pump (in my opinion) sounds like all the fuel is moving to the side of the tank thats away from the pump?!
scintaar
Post Thu Apr 07, 2005 4:14 pm
Double check the connection to the ECU... make sure it's nice and tight. Had a similar prob in a Turbo charged Monster... lost all power and cut out on corners. Turned out to be the ECU connector had come loose.
astondg
Post Thu Apr 07, 2005 10:03 pm
Maybe you just need another gear? :D
Aston
BMW E30 323i with some stuff
1:21.67 @ Morgan Park Raceway
