Brake conversions, front and rear
Sidrick
I've decided I'm going to keep my E30 316i after a faily successfull MOT and do an engine conversion. I'd like to get the stoppers sorted out first though.
I'd like to upgrade to bigger, vented discs at the front, and change from drums to discs at the rear.
At work I've got some E36 M3 front brake calipers and some E30 320i Touring rear brake calipers? Is there any well known conversions that involve either of these?? Can anyone point me to a guide or a how to, or maybe just fire up a quick list of what I'll need?
Many thanks.
Many thanks.
BadDave
This is what can be done if you want some serious braking capability
Check out the link below
http://www.e30zone.co.uk/modules.php?na ... ic&t=58675
Ant
- Retired Team Member
given the currently modest power level, best bet is swop in the front nd rear subframes/suspension from a touring, Discs all round, bigger struts , more potential for future mods....
Cheap proven and available, works for me
upgrades on the O.E stuff..
Previously fitted a 300mm.de kit to a customers turbo conversion, that thing STOPS no fade even with heavy abuse
Just fitted the Wilwoos 280mm kit to another customrs car, not fully bedded yet, but great feel/feedback, and pulls up very nice indeed when compared to the drilled/grooved setup it replaced( new FYI, but not enough... )
rear upgrade is Z1 rear discs with e30 M3 calipers/carriers.
Email FTW
Did you feel any difference between the e30.de setup and the Wilwoods Ant?
Im planning on buying the Wilwood kit soon so would appreciate your comparison
Morat
I think the decision between wilwood and 300mm kits will be what wheels you want to run. IIRC Willwoods just fit under 15" BBS so I assume the 300mm disks will need 16" at least.
BadDave
IIRC 280mm discs will fit under a 15" wheelMorat wrote:I think the decision between wilwood and 300mm kits will be what wheels you want to run. IIRC Willwoods just fit under 15" BBS so I assume the 300mm disks will need 16" at least.
300mm discs Definately need a minimum of 16" wheels.
jaistanley
For the brakes on my project car I'm going with the following:
Front:
Using E30 M3 front struts atm (with rebuilt calipers, braided hoses and std disks and pads). They're an improvement on std stuff for sure.
Going to be fitting the calipers from an E36M3Evo/MCoupé (bolt straight onto an E30M3 strut) and the front disks from the same car (the 2 piece disks with ally bells and 315*28mm disks). To fit the disks you need to take the hub offset of the E30M3 hub to the same as the E36, along with the spigot diameter so hubcentric spacers are required behind the disks. This means the front struts now required wheels with the E36 fitment.
Rear:
Currently using E30M3 stuff here too, again an improvement over std but not enugh for S50 power
. Going to be installing the trailing arms, brakes, diff and driveshafts from an MCoupé. The arms are strengthened, along with the driveshafts and the brakes are 312*20mm (vented), with a piston diameter matching the front calipers (so balance will be spot on).
I will be fitting E36 17" wheels to allow clearance and match the offset of the hubs front and rear. I have the split rim BBS 17" wheels from an E36 328i sport (though I have two sets of 7.5" fronts rather than a front and 8.5" rear for clearance on my non M3 shell). I beleive I shall have to fit 215/40/17" tyres for the same reason.
I shall be using a 25mm master cylinder (from an Audi for plenum clearance, a 750i master cylinder can be used on the E30 setup with these brakes) as this is the size used in the original cars (E36M3Evo and Mcoupé).
Its a nice bolt on sollution using pretty much all OEM parts (apart from spacers). A further upgrade from here would be to fit the disks and calipers from an E46 M3. After that I beleive the aluminium 4 pot calipers from a later 840i series will bolt straight on with the E46's 342*28mm disks (providing you have the wheel clearance). I am yet to find out if the E46 M3 rear disks and calipers will fit onto an MCoupé rear end, but will do in the future (S14.net boys are very thorough!). AP do a bolt on twin pot caliper for the MCoupé rears which is another possibility.
Hope this helps someone...
Good luck mate.
Jai
Front:
Rear:
Good luck mate.
Jai
Ant
the Wilwood 280 mm kit gave good progression, zero fade and pulled up about 50% better than the existing O.E setup I removed
The 300mm.de kit is perhaps more progressive in action, but the weight of the assy works against it IMHO.
Both kits were a major upgrade on new stock sized components
I'm using the 310mm Wilwood kit on my car as soon as I get my 16" rims back from refurb.
I melted the seals in my calipers when she was F.I, did 3 sets in the summer
not happeneing again this year ...
Email FTW
awx
Do these brake kits have any problems with ABS?? or is a NON-ABS e30 prefered for Wilwood/movit and the like?
blingsta
- Boost Junkie
I melted the seals in my calipers when she was F.I, did 3 sets in the summer not happeneing again this year ...
Damn, i better be thinking of an upgrade too then... i think the 5 stud conversion from the z3 is def the cheapest option..
Demlotcrew
Thats because the Wilwood callipers are just kack, they are supper soft and flex under the slightest pressures.Ant wrote:The 300mm.de kit is perhaps more progressive in action, but the weight of the assy works against it IMHO.
I do agree that the 312mm kit is a bit on the heavy side, but only by 1.6kg over stock and they more than make up for it in performance. Coupled together with alloy arms they work a treat.
You need to remember that with the 312mm kit, alloy arms and a lightweight wheel the mass will still be less than lets say running BK 17" replicas.
Andrew
Turbo-Brown
- Boost Junkie
Would like to know what you're basing that statement onThats because the Willwood callipers are just kack, they are supper soft and flex under the slightest pressures.
jaistanley
I want some ally arms and Compomotive 16"s to go over my 315mm E36 disks and calipers.
The disks are a little lighter (alloy bonded bell), the alloy arms are strong and light and the Compomotive wheels are strong, light and trés cool!. Set of alluminium 4 pots and I'm Uber light unsprung!
Jai
Jai
Morat
but but... BK 17" reps make the baby jesus cry..
(for less unsprung mass, anyway)
Turbo-Brown wrote:Would like to know what you're basing that statement onThats because the Willwood callipers are just kack, they are supper soft and flex under the slightest pressures.
Never heard anything like that said about Wilwood before
Turbo-Brown
- Boost Junkie
Indeed, neither have I. Not even about the early cast ones such as my mate uses on his race car, and I'd be extremly surprised to hear about flex issues with the later forged calipers.
However, I stand to be corrected.
BadDave
I'M using a nice big pr of brembos with ABS and not having any problemsawx wrote:Do these brake kits have any problems with ABS?? or is a NON-ABS e30 prefered for Wilwood/movit and the like?
HTH
Turbo-Brown
- Boost Junkie
All the ABS is looking at is the rate of wheel deceleration. Ultimately, your braking performance is limited by your tyres (unless the brakes are really crap) as all the brakes do is decelerate the wheel/tyre assembly.
That said, I believe it's easier to modulate your braking more effectively with powerful stoppers than tiddlywinks where you might have to stamp the pedal to it's stop just to lock up.
I guess that more powerful brakes could also allow you to make better use of stickier tyres.
awx
Cheers.. The only prob with Wilwood - they dont answer their f**kin emails
jaistanley
Have you tried ringing rally design? They are the distributors for them in the UK I believe.
Jai
Jai
gareth
the piston area makes the biggest difference to ABS operation. the systems use a timed pressure discharge to reduce the braking and hold the wheel back from locking. increasing the piston area significantly will reduce the amount the ABS system can drop off the line pressure and hence braking effort. this is because of the larger volume of fluid that needs to be released to achieve the required line pressure drop.
this is one of the main design advantages of the WMS kit over 'some' others, keeping a similar total piston area to the stock brakes will let the ABS do it's job correctly and also remove the need to 'upgrade' the m/c to suit ill matched calipers.
jaistanley
I can see your point but I have some reservations about it... The actual volume flow rate of brake fluid must be tiny in a braking system, the braking being more pressure dependant than volume. I'm sure the ABS adjusts pressure by metering the time the solenoid is open but I have a hard time beleiving it would make a noticeable difference. Look at the diameter of your brake lines; they are similar/te same for all manufauctureres regardless of the diameters of both master and slave pistons suggesting to me they have such low flow rates.
Also: aren't ABS systems closed loop? ie they monitor the pressure in the lines and open and close their solenoids till the line reaches a certain pressure, determined by the pre set histeresys of the system. Then the only concern is that the solenoid has become under-specced and can't release pressure fast enough. I find this extremely unlikely. As en engineer you simply would not spec a system so close to it's maximum capacity.
I'm open to being convinced though.
If I can gather the sizes of the master cylinders, slave cylinders and the brake pipe I could do some math to calculate the difference in flow rates of the system and therefore a percentage of reduction in pressure per unit time of the ABS system...
I have a feeling it'll be alright though, I'm personally going to 'suck it and see' when I've installed my brakes.
Jai
Jai
gareth
i am also an engineer and have an idea on how complex the parameters are within the ABS ECU.
i agree that the volume flow rate is tiny but the system can't remove fluid in a volumetric manner, instead it uses very quick (milisecond) pressure venting pulses while aso blocking off the pressure inlet. the ABS ECU may well know the pressure in the system but you have changed the active area of the calipers and hence the volume of fluid moving, hence the time required to release volume to reach the new required pressure will be longer.
in essence, the system could be 'mapped' for use with other calipers etc to get their full potential but this way beyond what us mere mortals are capable of. this is where mega bucks is spend by manufacturers to calibrate and map the system.
in the case of the E30, i don't know of anyone having severe problems with the ABS after brake upgrades but i do know of other makes (vauxhall in particular seems to ring a bell) that do have problems. the ABS system detects that the wheel isn't slowing down like it has been told to do and the system resets, giving you a firm pedal and no brakes for a second or so!!!!
regardless of how severe the problems are, you can't disagree that an ill-matched setup will affect the operation of the ABS to some degree and this won't be an improvement.
suck it and see is a good principle but don't throw out the fundementals of how the system works just to use a convenient caliper that someone stocks in bulk. the reason a lot of kits have badly matched piston areas is simple, there are a lot of different caliper styles and piston sizes required to cover all models and kit sizes effectively and this costs more money due to needing larger stock levels.
exup
- Boost Junkie
Yep understanding the Engineering principles really helps when modding , , shame most kid s today just like the x boxs etc
Try Hi spec calipers / kits , they are much better /lighter than W/WOOD and cheaper than A.P , there good blokes ,+,lady , with excellent back
and as to ABS problems , Gareth , your thinking is correctie volume flow rate is just pulsed , very quickly agreed , and the pulse is split equally to each pistion ideally , but you will have no problems with a reasonable up grade , in caliper size ie 2 pot to 4 etc
Mny years ago I Did a a 255 to 360 mm disc converstion with 6 pots which work just fine and its the same ABS SYSTEM as an e30 worked brill
jaistanley
Are Hi-Spec calipers available with road going dust seals? A friend has some on his rally car (and gets a healthy discount for having HiSpec livery on it, shame I cant get the same) and they don't.
A friend with an E36 M3 GT (the one based on the 3.0 litre) has just won the bidding on some porsche 996 carrera calipers (front and rear). Using Inventor we're gonna design the spacers and spec the disks for a simple conversion to E30 and E36 M3 hubs using (hopefully) OEM disks from BMW or possibly off the shelf disks and bells. I'm diong it more as an academic exercise (to learn how to use inventor properly, I'm an AutoCAD and Catia monkey) but we'll see how good it is on his car.
Jai
Jai
gareth
exup, the critical thing is the total piston area. do you know what the piston sizes were on your 6 pots? 6 pot calipers usually have very small pistons to keep the area down
