Head light adjusters
chu346
Post Tue Feb 20, 2007 4:39 pm
Can the head light adjuster knob and cabling be removed? I looks like a funny clear cable of some sort that I haven't come across on other makes of car. I don't want to snip it and bad things happen like it leaks out fluid etc.
316eyes
Post Tue Feb 20, 2007 5:09 pm
Yeah you can disconnect it, not much will come out. Leave the black plastic fitting on the headlight in place as you can manually adjust the h/lamp with the knurled bit.
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
