just put some new rear discs on my car.now i cant get the calipers back on.
its probly simple but i havent done it before so i dont know how its done.
any help appreciated
new discs
buckz2001
have you pushed back the caliper pistons yet?.........
sam325is
no. how do i do that?
Stick a bleed hose on the bleed screw and slacken it off. Then push the piston back in squarely.sam325is wrote:no. how do i do that?
In the absence of a proper tool, the easiest way is to stick a screwdriver between the disc and the old pad on the piston side before you dismantle anything.
Conrad
Wouldn't that result in you having to bleed the brakes afterwards? I was always told to take some fluid out of the MC.Brianmoooore wrote:Stick a bleed hose on the bleed screw and slacken it off. Then push the piston back in squarely.sam325is wrote:no. how do i do that?
Cheers,
Con
No, as long as you close the bleed screw before releasing the pressure on the piston.Conrad wrote:Wouldn't that result in you having to bleed the brakes afterwards?
Doing it your way forces dirty fluid from inside the callipers back through the system, and can possibly damage seals (by reversing them) inside the ABS pump unit or the master cylinder.
Lordschleife
Thats what I usually do - use a screwdriver between disc/pad before taking offBrianmoooore wrote:Stick a bleed hose on the bleed screw and slacken it off. Then push the piston back in squarely.sam325is wrote:no. how do i do that?
Now the calipers off you might be able to use something like a g-clamp with a thick cloth round to push the caliper back if it doesnt want to shift easy
Cheers,
Robin
Robin
