manifold
salami
Post Mon Feb 19, 2007 7:02 pm
Can an exhaust manifold be welded and if so in place?(crack is underside)
charlE30
Post Mon Feb 19, 2007 7:34 pm
I don't think cast metal can be welded, cheaper enough to get a second hand one...
Or do you have a six brancher???
BMW F31 335d xdrive
Turbo-Brown
Boost Junkie
Post Mon Feb 19, 2007 8:02 pm
You can weld cast metals, it's just a lot of palava as they should be pre-heated typically.
I'd say that the location of the crack and the need to pre-heat would probably rule out welding in place.
Stand to be corrected though.
charlE30
Post Tue Feb 20, 2007 1:24 pm
Turbo-Brown wrote:You can weld cast metals, it's just a lot of palava as they should be pre-heated typically.
:o: I learn something everyday :o:
BMW F31 335d xdrive
Post Tue Feb 20, 2007 1:46 pm
One of the cast manifolds on my M50 was welded (section removed), and hasn't failed yet.
Was done for me by a professional welder, when I wasn't around, in exchange for fixing an electrical fault in his workshop.
