Part 16 on this diagramoakey wrote:thanks mate but youll have to forgive me as i dont know much about this sort of stuff= where should it be attatched? whats it for? how do you think it came off?
i think no.14 on the digram is the bump stop, the part in querstion is just a cover for the top mounted325i wrote:Its the rear bump stop.
Which also damages the subframe bushes and the flexi brake pipes.berto wrote:no you dont, just push the arm down lower and pull the old one out, or just use a long bar and pop it out.
You undo the shock lower bolt (number 3) and then just push the trailing arm down and the spring will just pull out.smithy318i wrote:Which also damages the subframe bushes and the flexi brake pipes.berto wrote:no you dont, just push the arm down lower and pull the old one out, or just use a long bar and pop it out.
