window help
MARTYCAB
Post Sat Feb 17, 2007 10:47 pm
hi there after some help please regarding the electric windows on my cab .the windows only open or shut when the doors are open i have tested the voltage when the doors are open i have 12 volts when i manually press the door switch voltage drops to 0 volts .when the doors are shut you turn on the igntion there is no voltage at any of the switches please can some help me find out how the system works
thanks
SPADGE
Post Sat Feb 17, 2007 10:48 pm
Check the small green/black wire on the smallest terminal of the starter motor and make sure it is making a decent contact
Alyman
Post Sat Feb 17, 2007 10:51 pm
I'm rubbish with electric stuff, but if I recall correctly the windows use a different fuse when the doors are open - maybe the fuse that normally deals with them when the doors are closed has blown?
Post Sat Feb 17, 2007 11:01 pm
Check fuse 17 (windows, roof with ignition on).
If this is OK, pull out relay K5 in the fusebox and short together pins 30 and 87 of its base with a short piece of wire. If this makes the windows work, then do as Spadge says.
MARTYCAB
Post Sat Feb 17, 2007 11:41 pm
thanks people will carry out some checks in the morning . thanks again brainmoooore you gave me some advice on a problem i had with the in tank transfer pump . i got a brand new replacement from America on ebay £90 posted so bit of a result bmw wanted £150 + vat .anyway it solved the problem cars running ok thanks again
